ep92 pinout diagram
ep92 pinout diagram
Postby tsoob » Thu Sep 11, 2008 5:31 pm
does anyone have a link to the ecu pinout's for this car?
Thanks,
Nick
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby slammed_integral » Thu Sep 11, 2008 7:09 pm
no such thing as ep92 u mean ep82 or ep91? i got both i think
http://www.cardomain.com/id/slick_ep
there is nothing sour cola worms cant fix...
slammed_integral
Postby tsoob » Thu Sep 11, 2008 8:16 pm
sorry had ae92 on my mind, its a ep82 can i have it ??
Thanks
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby slammed_integral » Thu Sep 11, 2008 9:05 pm
year and auto or not
slammed_integral
Postby tsoob » Fri Sep 12, 2008 4:39 pm
slammed_integral wrote:year and auto or not
its a 1990 its manual thanks.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Stu- » Fri Sep 12, 2008 5:44 pm
Just unscrew the cover on the ecu - the pins are clearly marked.
Project Thread
Stu-
Postby slammed_integral » Fri Sep 12, 2008 7:36 pm
you manage to find out? because i ahve them here but they arnt lebeled which year :oops: soooo heres
4E-FTE EP82 ECU 89661-10040 GREEN STICKER ma-5450
26 pin plug
1 ~ ~
2 NSW Neutral Starter Switch
3 THW Water Temparature Signal
4 PIM Pressure Intake Manifold
5 THA Intake Air Temparature
6 IGT Ignition Timing
7 IGF Ignition Feedback from the Ignitor-Coil
8 G1 Distributor
9 G- Distributor Crank Angle
10 OX Oxygen Sensor (Lambda Sensor)
11 STA Engine Cranking Signal (Starter Switch)
12 #10 Injector Pulse 1 & 3
13 E01 Computer Ground
14 DISC Aux. Control Valve or Idle-Up System Vacuum Switching Valve
15 VSV1 Air Control Vacuum Switching Valve
16 E2 Sensor Ground
17 PSW Throttle Position Sensor
18 VC
19 IDL Throttle Position Sensor (Signals ECU throttle position is at idle)
20 G2 Distributor
21 NE Part of the IIA (Intergrated Ignition Assembly) (RPM)
22 E21 Sensor Ground
23 KNK Knock Sensor
24 E1 Computer Ground
25 #20 Injector Pulse 2 & 4
26 E02 Computer Ground
16 pin plug
1 +B1 Switched Battery Power (12V)
2 BATT Switched Battery Power (+12V) (EFI Main Relay)
3 CCO Check Connector Outputs
4 FC Circuit Opening Relay (Fuel Cut)
5 ELS Electrical Load Signal System Taillight Relay
6 AC2 12V To Aircon Computer
7 BC Boost Control
8 T
9 +B Switched Battery Power (12V)
10 W Warning Light
11 EGW Catalytic Converter Temparature Warning Light (Combination Meter)
12 ~ ~
13 SPD Speed Signal
14 ACT A/C Cut Control System
15 AC1 A/C Switch Signal System (12V to Aircon Computer)
16 VF Check Connector Outputs
slammed_integral
Postby slammed_integral » Fri Sep 12, 2008 7:37 pm
4E-FTE EP82 ECU 89661-10100 BLACK STICKER 211000-0550 12v
4E-FTE EP82 ECU 89661-10100 GREEN STICKER ma-5970
26 pin plug
1 IPV Vacuum Switching Valve
8 G1 Distributor
16 E2 Sensor Ground
18 VC
20 G2 Distributor
23 KNK Knock Sensor
16 pin plug
7 TE2 Check Connector
8 TE1 Check Connector
10 W Warning Light
12 AC1 A/C Switch Signal System (12V to Aircon Computer)
13 SPD Speed Signal
15 BC Boost Control
slammed_integral
Postby tsoob » Wed Sep 17, 2008 2:18 pm
hey thanks mate will let you know if there are anymore issues we are doing a link on it.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
