Hey im just after some advice on rebuilding my 4age, was looking into getting some high comp wisco pistons has anyone used these before? Would they make much of a difference and will i need to start running aftermarket ecu? Would there be much of a gain over the standard pistons? or mainly just stronger? Also lightning the flywheel how light can i go or should i just try and get a black top flywheel?
And if anyone has a modified blue top what sort of power figures have you got with certain mods?
The motor is going to go in my starlet
