20v experiences??
20v experiences??
Postby d1 mule » Thu Jan 15, 2009 10:59 pm
heya so me being capitan indecisive and all have had the thought of a mildly worked blacktop 20v in the 70 instead of going the turbo route.
the plan would be .5mm TRD head gasket, extractors, trumpets, tuned on AVGAS
wold it be worth it???
any ideas what sort of power it would muster??
d1 mule
Postby Bling » Thu Jan 15, 2009 11:11 pm
Probably not much more than factory.
Power delivery would be different though (probably worse) if you changed the trumpets / extractors. Add some cams to the mix and they can get up to 110kw+ ish atw. Ball park figure to give you an idea anyway.
Yep i'm biased but just running it factory would still go alright 8)
Postby d1 mule » Thu Jan 15, 2009 11:21 pm
oh that not alot more than its got now (75rwkw 16v 4age) was hoping for about 130-150 rwkw
cheers :D
d1 mule
Postby matt dunn » Thu Jan 15, 2009 11:27 pm
d1 mule wrote:oh that not alot more than its got now (75rwkw 16v 4age) was hoping for about 130-150 rwkw
cheers :D
wont get that without boost.
Postby Leon » Fri Jan 16, 2009 8:04 am
NB: remember that MSNZ is banning leaded fuel, thus Avgas, in the not distant future. So don't build a motor that is going to require fuel that is getting the ban stick.
Postby matt dunn » Fri Jan 16, 2009 9:37 am
Leon wrote:NB: remember that MSNZ is banning leaded fuel, thus Avgas, in the not distant future. So don't build a motor that is going to require fuel that is getting the ban stick.
and it is illegal to use on the road too.
Postby Bling » Fri Jan 16, 2009 9:49 am
Drifters follow no rule book :twisted: :lol:
Postby d1 mule » Fri Jan 16, 2009 9:52 am
haha its not till 2010 they are banning it isnt it??
ok then by the sonuds of it ill go turbo then, thanks for your help
d1 mule
Postby Leon » Fri Jan 16, 2009 9:55 am
BZG|Bling wrote:Drifters follow no rule book :twisted: :lol:
Actually, the drifters have some of the toughest roll cage requirements out there. Considering that they are running at Clubsport level anyway.
Yah, I think 2010 for avgas out, I don't have the info in front of me unfortunately.
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
