5000 pound twin plate clutch
Postby avinesh » Fri Jan 16, 2009 7:43 pm
i have heard of crank walk on 2jz with heavy pressure plate, really concerned with mine....i read about it after i got the 5000 pound clutch installed, really concerned now
220.1 rwkw
jzz30 bpu soarer auto = 13.3 @ 171 km/h
jza80 supra = 11.7
jza80 apu supra manual = 400rwkw
avinesh
Postby lucasthefallen » Fri Jan 16, 2009 8:06 pm
A very heavy clutch will put more thrust onto the crank. Could cause premature thrust washer wear.
Need Service or Repair work done? send me a PM
lucasthefallen
Postby Burning Angel » Fri Jan 16, 2009 9:13 pm
i think the only issue is if you start the car with the clutch depressed as there is no oil being pushed past the thrust washers.
so just start the car in neutral with foot off the clutch(i think in supras you need to bypass the clutch switch to do this)
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby avinesh » Fri Jan 16, 2009 9:25 pm
lucasthefallen wrote:A very heavy clutch will put more thrust onto the crank. Could cause premature thrust washer wear.
the clutch pedal feel doesnt feel like 5000 pound an its a r154 gear box im starting to think what if its not 5000 pound.....the twin plate presure plate has been modified though by clutch rebuilders....
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby Si » Fri Jan 16, 2009 10:12 pm
Is it still a pull clutch system or has it been convereted to push?
Current: , '96 SubaruImpreza
Si
Postby avinesh » Sat Jan 17, 2009 10:14 pm
Si wrote:Is it still a pull clutch system or has it been convereted to push?
still pull type exedy twin plate
220.1 rwkw
jza80 supra = 11.7
avinesh
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
