Hey just wondering what is needed to run them on a 4age? Is it as simple as just getting a manifold and bolting them up with fuel lines and linkage kit?
You will need manifold,carbs,linkages,fuel lines, & a suitabl fuel pump & fuel pressure regulator,air filters etc. You'll also need to suss out something as far as ignition goes.
