Measuring Air Intake
Postby celica_xr9145 » Sun Mar 08, 2009 10:34 am
Is there a gauge that measures air intake?
I thought it was a vacuum gauge but im not sure.
Its not for a turbo car, its for a N/A.
www.Garage-X.org - Car Awesomeness
Facebook.com/garagexnz - Now on FB!!
95' Zenki Silvia S14, 99' BMW 328i E46
celica_xr9145
Postby BlakeNZ » Sun Mar 08, 2009 10:54 am
you can buy a vacuum gauge, but are rare, so you can just use the vacuum half of a cheap boost gauge. As far as i know, there is nothing available that can measure air intake( in terms of cubic feet per minute) on your car.
BlakeNZ
Postby jakesae101 » Sun Mar 08, 2009 12:24 pm
vac gauges are cheap the supercheap brand gauges are like 64 $$$ or something like that for a vac gauge
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby celica_xr9145 » Sun Mar 08, 2009 2:28 pm
thats not bad, someone on here is selling a blitz vacuum guage for around $75.
How do you fit them and where do you plug them in?
celica_xr9145
Postby Lloyd » Sun Mar 08, 2009 2:48 pm
You join it into a vacuum hose coming off the inlet manifold after the throttle body
Postby 20v_rollaboy » Sun Mar 08, 2009 11:43 pm
Ive got a Blitz vacuum gauge, you can have it for less that $75.
20v_rollaboy
Postby sergei » Mon Mar 09, 2009 8:22 am
Why do you want to measure air intake?
I assume it is for your Celica? Does it have AFM?
Digital Voltmeter on the one of the AFM pins will show how much cubic meters are coming in if you can calculate what is the ratio of Volts vs cubic meters (which is possible with measuring duty cycle of the injector on near stoich with working oxygen sensor).
But having vacuum gauge is pointless.
Vacuum gauge will not show flow directly. It will show same readings on 8L engine as 1L engine on full/partial/closed throttle.
