1zz-fe pistons
1zz-fe pistons
Postby Volodkovich » Sun Mar 15, 2009 10:45 pm
Hi all,
Looking at fitting some 1zz-fe pistons into another motor and was wondering if anyone had or knew of the specs of them - basically i know they are 79mm and have a 20mm gudgeon, but need to know the compression height (distance between centre of gudgeon pin and the top of the crown), as well as the standard dish volume.
If anyone has these specs, or even an old piston they dont want i'd love to check them out.
Cheers,
Rob
Volodkovich
Postby barryogen » Mon Mar 16, 2009 1:14 pm
have a look at newcelica.org
They have all sorts of info on the 1zz and 2zz.
barryogen
2ZZ Guru in training
Postby Mr Revhead » Mon Mar 16, 2009 1:39 pm
viewtopic.php?t=58219
may have the info there
Postby Volodkovich » Mon Mar 16, 2009 2:34 pm
Hmm, cant seem to find it. From the cross sections i have worked it out to be roughly 35mm, but its kinda hard to tell.
What sort of price would a new set from Toyota be?
Volodkovich
