clutch slip or something else?
Postby jakesae101 » Tue Apr 21, 2009 7:20 pm
when im accelerating round corners and accellerate quickly in first i get a shuddering that feels like clutch slip only does it around corners any ideas im thinking clutch possibly slave cyl had the fluid changed and bled clutch up less than a month ago in my ae92 gtz
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby cedwards » Tue Apr 21, 2009 7:29 pm
Sure its not just your inside wheel slipping with no weight and a sudden increase in torque on it?
Can test your clutch by driving in a straight line engine about 3K pushing clutch in revving engine to about 4k and dropping clutch should drop back to 3k quickly and smoothly if it takes a while then clutch is getting tired. A little bit of slip can be expected but not excessive amounts.
cedwards
Postby jakesae101 » Tue Apr 21, 2009 7:32 pm
it does do that yesterday it was bad in the wet it does feel like clutch slip if i hammer it off the line though it has done 274000ks and i have no idea when the clutch was done
jakesae101
Postby rollaholic » Tue Apr 21, 2009 9:53 pm
clutch slipping would result in revs flaring with no resultant increase in wheel speed
sounds like single spinner failing to handle the jandal to me
Postby AE82 FXGT » Tue Apr 21, 2009 10:34 pm
rollaholic wrote:sounds like single spinner failing to handle the jandal to me
most likely explanation
AE82 FXGT
Users browsing this forum: Google [Bot] and 2 guests
