I've had in my possession for over a year, a new, still in box, HKS style 40mm wastegate.
I'm wondering what people thing of these? At the moment I'm using an Audi wastegate that's only 32mm and I'm worried when I wind the boost up, it might be a bit small and might not be able to vent enough.
I'm having to cut and rotate the wastegate anyway, to make room for bigger brake master cylinder stuff
Should I just chop the Audi flange off and weld the hks style one on and use that wastegate?
Does anyone use these wastegates?
I have boost cut on my ECU so if anything goes wrong with the wastegate, I wont overboost....
The wastegate looks like this:
