postfach wrote:Malcolm wrote:I would think it would be better to have the cooler (and therefore lower volume) air flowing through the smaller pipe
I don't think this statement is true - if the air is cooler, it becomes more dense, and since the entire system is pressurised with probably less than 1psi difference between pre-and post-cooler, then the volume of air after the cooler is actually going to be greater than before it.
hot air expands cold air contracts,
everybody has different theories on this and most setups will work fine,
guys that deal with gas turbines will tell you, you need 3" from the turbo and 2" to the throttle body.
personally id run 3" all the way if there is room for it and dependant on the length of the piping,
I run 3" on hot and cold sides on my rx7 and so does the 2j altezza both with excellent results,
