Is there a 4 pot upgrade for st215w Caldina?
Postby drftdr » Mon Jun 08, 2009 6:18 pm
Is there a decent calliper upgrade for the Caldina wagon?
Brought a st215w wagon for the mrs, and going from a s15 spec s to the wagon, the brakes suck in comparison.
My knowledge base is mainly in the nissan family, so if anyone knows of
a decent upgrade please do enlighten me
Drftdr
drftdr
Postby GTTpower » Mon Jun 08, 2009 6:27 pm
Dont know of any 4 piston upgrade for the caldina. K Sport do an 8 pot upgrade - here
1999 SXE10 Altezza RS200Z
2004 Honda SCV100
Steam/Origin ID: nzEP85
GTTpower
Postby frost » Mon Jun 08, 2009 6:33 pm
i would suspect the caldina gt-four would have 4pots.
Postby drftdr » Mon Jun 08, 2009 6:57 pm
Nope only a big 2 pot calliper.
Any one with a really nice setup on there wagon?
Read mintex 1166 pads, what about rotors?
The brakes just suck in comparison to other cars driven
Drftdr
drftdr
Postby Bling » Mon Jun 08, 2009 9:05 pm
In comparison to other WAGONS or other CARS you have driven? :lol:
Postby GTTpower » Mon Jun 08, 2009 9:09 pm
drftdr wrote:Nope only a big 2 pot calliper.
You have to be realistic, a 1400kg+ 4WD wagon is not going to have the brake performance of a Silvia. Braided lines, good pads and decent tires do a good enough job
2004 Honda SCV100
GTTpower
Postby CelicaGT8 » Mon Jun 08, 2009 9:19 pm
Prety sure st205 4pots fit, may have to run different discs If not you can always adapt.
CelicaGT8
Postby matty_j24 » Mon Jun 08, 2009 10:19 pm
im 99% thru fitting st205 four pots to mine pretty easy conversion pretty self explanitry what you gotta do once you put the caliper up next to the hub
matty_j24
Postby drftdr » Mon Jun 08, 2009 10:30 pm
Yeah ive been reading thru the web on the st205 brake upgrade
Anyone have any recommendations on where to get some from?
Also said to use a 305mm brake disc
The more info i can gather the better
Only other wagons i have driven have been 260rs wagons.
My work wagon is a 2007 wingroad, and that has a much nicer pedal feel.
Car has 18 inch work wheels, not much heavier then the factory 15's
and 235 toyo equivilant tyres.
Grips really well and goes well, just not impressed with the brakes
And being the mrs's car, gotta be nice and safe.
Drftdr
drftdr
Postby matty_j24 » Mon Jun 08, 2009 10:38 pm
i am running machined down st205 rotors to keep everything lining up, subaru rotors have a different hat height which means you have to $&#$% around with spacing after i got the discs to the right size you are correct 305mm i just put a thread into my factory hubs and your pretty much done i havn't looked at the brake hoses yet but its no biggy to get some new ones made up that are slightly longer. there is a set of gt four four pots and 2 pot rears on trademe at the moment i would reccomed buying some brakes with rotors if you can because they are not cheap at all i spent a few days at work ringing some suppliers and your looking at over well 100+gst per disc cant remember the exact figure but it was not cheap!
matty_j24
Postby drftdr » Mon Jun 08, 2009 11:09 pm
There is, send me link, i did a quick search
I have mate whom works at repco, so if in doubt new disc.s
Thats good to know the info i read has been confirmed by someone here in nz doing it, cool and cheers.
Drftdr
drftdr
Postby bs » Tue Jun 09, 2009 8:12 am
drftdr wrote:There is, send me link, i did a quick search
http://www.trademe.co.nz/Browse/Listing.aspx?id=223074946
bs
Postby KinLoud » Tue Jun 09, 2009 2:42 pm
Hmmm - almost sounds like you are dealing with different pedal feel from what you are used to rather than poor braking performance.
Best feel brake pedal I have driven was NZ new 1995 camry wagon... rock solid pedal that hardly moved when you applied brakes.
Crappiest feel brakes is in my Carina racecar! Quite a long pedal movement, but boy does it stop hard!
Different makes and models have different feels to the brakes...
If you do for ST205 4 pots you will probably find you will get a much longer pedal due to the extra piston area.
Ken
Postby RomanV » Tue Jun 09, 2009 2:50 pm
Heh, funny you say that Ken, as something I've found out...
"Late model Camry 2 bolt brake master cylinder (p/n 47201-06190) bolts directly to TA22/AE86/TE72/AE71 booster for those running bigger brakes & needing to get rid of the spongy pedal ST205 celica fits also, but lines are slightly different."
I think the camry had the largest bore in the MC out of all the things that would fit the 2 bolt brake booster.
Postby drftdr » Tue Jun 09, 2009 6:32 pm
I know from doing a 4 pot conversion on my laurel when had it the pedal feel never changed. Didnt change the master cyclinder either.
Its pedal feel and poor braking. I know a pad change and disc change would help, but i do love having good brakes.
Drftdr
drftdr
