Silvertop & Blacktop Qs
Postby FANGIN » Wed Jun 10, 2009 4:09 pm
Are the part numbers for the following items the same for both a blacktop 4age & silvertop 4age?
The reason why I'm asking is that im going from a blacktop 4age to a silvertop 7age & am wanting to reuse the sensors/senders without having to rewire if i can.
Water temp sensor
TPS
vvt controller
1998 AE111 Carib - For Sale!
1999 JZS161 GS300 - Tow Wagon
1986 FC3S - 410wkw Drag / Track Toy
FANGIN
Re: Silvertop & Blacktop Qs
Postby 1I1 » Wed Jun 10, 2009 4:46 pm
FANGIN wrote:Are the part numbers for the following items the same for both a blacktop 4age & silvertop 4age?
Water temp sensor
TPS
vvt controller
Water temp sensor for the ecu is the same. TPS are different. VVT controller? Meaning the switch on the exhaust side of the head - are the same
TRD Clicky >>Here
1I1
Postby Bazda » Wed Jun 10, 2009 5:37 pm
The VVT switch is different on the BT and the ST. They look totally different.. Not sure if they function different..
Postby 1I1 » Wed Jun 10, 2009 5:55 pm
Sorry the vacuum switch is different, the one on the head is the same
TRD Clicky >>Here
1I1
Postby FANGIN » Wed Jun 10, 2009 6:01 pm
Cheers guys, Also, are the dizzys the same?
Yes, vvt switch on exhaust side of the head.
FANGIN
