Blocking Diode advice
Postby cat007 » Fri Jun 12, 2009 9:22 am
Hey all
I have a question regarding a blocking diode I have purchased
It's a HEHR branded one - like this: http://www.hehr-international.com/isolators.htm
It's rated to a 130amp alternator (I'm putting a 120amp alternator in)
The idea being you can charge two batteries separately without either batteries talking to each other. So if one goes flat from lights etc. the other still is fine.
I want to know - if one is flat - the alternator is going to go balls out to charge it. But that would mean that the other battery that is charged is going to be overcharged?
Postby Stealer Of Souls » Fri Jun 12, 2009 1:37 pm
My understanding of all this (and it is definitely not exhaustive or complete) is that yes... with just a simple blocking diode system you will tend to overcharge one battery. This effect can be minimised by having two identical batteries.
I believe it is to do with the internal resistance of the batteries. Supposedly the best way is to buy a controller that can ensure the correct voltage/current is applied to each battery.
'86 AE85.5 Levin
Stealer Of Souls
Postby johntramp » Fri Jun 12, 2009 3:18 pm
If it works like this you will have no problems if one battery is flat.
johntramp
Postby cat007 » Fri Jun 12, 2009 3:28 pm
johntramp wrote:If it works like this you will have no problems if one battery is flat.
It is like that - but that's not my point
I was wondering if 1 is flat and 1 is charged, will the charged battery become overcharged while the flat one is being charged. A reply from 4GA on NZICE was what I wanted to hear:
The alternator does not really put out current to the battery, the battery draws current from the alternator. So when one battery is flat and the other charged, the flat battery will draw a lot of current and the charged battery only a little.
If you were to measure the current from the diode to the battery for each battery it would be different and the current on the line from alt to diode would be the sum of the two.
Postby cat007 » Fri Jun 12, 2009 3:42 pm
Next question would be - does anyone know if its possible and how easy it is to change the internal regulators reference feed to an external source?
Postby johntramp » Fri Jun 12, 2009 4:20 pm
...as I said, you will have no problems if one battery is flat. :roll:
If you are talking about the voltage regulator on the alternator, one of the pins is a reference.
johntramp
Postby cat007 » Fri Jun 12, 2009 4:27 pm
johntramp wrote:If you are talking about the voltage regulator on the alternator, one of the pins is a reference.
Oh really? Sweet!
I thought it might be internal somehow. I assume the reference wont require very chunky wiring as it wont be carrying many amps?
I'm wanting the reference for the alternator to be from after the diode so the alternator can compensate for the voltage drop.
I've just bought a 120amp Holden VY alternator. I'll try and make up a bracket this weekend and swap the pulley over.
Postby matt dunn » Sat Jun 13, 2009 7:38 pm
No it wont overcharge a battery if one is flat.
they do not split the charge equally, the flattest one will take the most current.
Postby Stealer Of Souls » Tue Jun 16, 2009 6:01 pm
cat007 wrote:I'm wanting the reference for the alternator to be from after the diode so the alternator can compensate for the voltage drop.
Hmmm... won't this cause issues?
If you're wired after one of the diodes, you have no idea what the other battery is doing.
If you wire to each battery then you've just parallelled the batteries together. Yes? No?
'86 AE85.5 Levin
Stealer Of Souls
Postby cat007 » Tue Jun 16, 2009 6:06 pm
hmmm that is true??
Without running a dual sensing alternator I'm unsure how to overcome this....
Postby matt dunn » Tue Jun 16, 2009 6:34 pm
3 studs on the blocking diode,
Batt 1
Batt 2
And charge /alternator input.
Run a wire from the Charge/input wire through an inline diode, 6A or similar, and then to the sensing wire on the alternator.
Will make the alt charge slightly higher to compensate for the Voltage drop across the diode.
so say normal charge is 14.1V, may take it up to 14.5 or so.
and you should end up with about 14.1 coming out to the Batt 1 and Batt 2.
Postby cat007 » Tue Jun 16, 2009 7:05 pm
I have it wired so it goes - alternator to diode then to batteries then from the main batt to van fuses and from house batt to other fuses etc
Like that it would mean I would have to put the sense wire after the diode otherwise it wouldn't be able to compensate for the diodes voltage drop or be able to sense what volts the batterie are putting out?
Or am I looking at it all wrong? Is the alt supposed to sense what it is putting out or what the batteries are putting out?
Postby matt dunn » Tue Jun 16, 2009 7:25 pm
looking at it all wrong.
Batteries dont "put out" when charging.
The alternator needs to sense what itself is putting out.
Adding an inline diode in the sense wire should increse it enough to compensate for the dlocking diodes.
Postby cat007 » Tue Jun 16, 2009 7:50 pm
Ah ok
Thanks for clearing that up!
I'll go to dick Smiths tomorrow. A 5 or 6 amp diode should be ok? Any particular sort?
Postby matt dunn » Tue Jun 16, 2009 10:19 pm
cat007 wrote:Ah ok
just a nomal diode
http://www.dse.co.nz/dse.shop/4a3763780 ... View/Z3229
Postby cat007 » Wed Jun 17, 2009 10:02 pm
For some reason that link doesn't work. Just takes me to the dick smiths site.....
Postby Boosted_162 » Wed Jun 17, 2009 10:32 pm
Search Z3229 in the search bar at the top...
Postby cat007 » Wed Jun 17, 2009 10:34 pm
Ignore that last post - refreshed the page and it came right :)
Thanks for that - I didn't get a chance today - but I'll see if my local DSE store has one....
cheers!
