I did a search, couldnt really find anything that helped.
The rear left brake on my ae111 levin bzg (disc brakes) is noisy under braking, is there a Haynes etc guide that shows how to disassemble the brake assembly on an ae111 or a guide that shows how? I like to learn how to repair and maintain my own car so taking it to a shop is pointless, want to do it myself. Im guessing its a worn brake pad due to the sound of the squeal, but I need to check before I buy another set. Also, should I replace the right hand set at the same time? or does it not matter....
