windscreen wiper not working all the time
Postby cat007 » Thu Jul 30, 2009 7:04 pm
Hey all
The hiace has a new trick for me. On low speed it will only sometimes work
Wiggling the stalk doesn't do anything and when its not working the best way to get it working is turning them on high then while its moving still, put it on low and sometimes, only sometimes its will continue to work on low
When its working on low it doesn't cut out and the motor sounds normal
Dodgy relay maybe?
Help please :)
Hunt
Postby cedwards » Thu Jul 30, 2009 10:12 pm
worn bushes in the motor?
otherwise as you say dodgy relay,
try measuring the voltage on the motor terminals while it is/isnot going.
Should help you figure out if relay doing the business.
cedwards
Postby cat007 » Thu Jul 30, 2009 11:45 pm
cedwards wrote:worn bushes in the motor?
I'll get a meter out in the weekend and measure the terminals
thanks for that
Postby fangsport » Fri Jul 31, 2009 9:25 pm
grab another relay with the same pins from the relay box , and see if that fixes the fault. a whole heap quicker than getting test gear out
fangsport
Users browsing this forum: Bing [Bot], Google [Bot] and 21 guests
