by KinLoud » Wed Aug 05, 2009 8:32 am
Yes - any S series motor (1S, 2s, 3sge, 3sgte, 3sfe, 4sfe, 5sfe) will bolt to the C series bellhousing.
You might need to mill the face of the bell Or space out the clutch fork pivot and release bearing to make the clutch release work with the later engines (3s onwards).
Lada is rwd? So you might have issues with clearance between the firewall and the water outlets on the back of the engine, also throttle body if you use a fwd motor.
There are rwd versions of some 4sfe and 3sfe engines I think
Ken
