What size/type of fitting should i get welded onto my sump for the turbo oil return?
Any info would be appreciated.
steve murch wrote:depending on size of turbo the bigger the better
t3 size turbo should be no smaller than 19mm pipe,no tight bends or rubber bends that aren't designed to used on turbos,they collapse under heat.
oil doesn't come out of a turbo as a liquid its look more like candy floss thus that's why you need a bigger return pipe than feed.
deaf_rattle wrote:steve murch wrote:depending on size of turbo the bigger the better
thanks Steve, turbo is an alltech sourced GT3582R.
Cully has suggested an earls type fitting, just gotta work out the size.
Py7h0n wrote:Don't use a earls fitting if you can avoid it. They are overpriced for something that can be done a lot easier.
cat007 wrote:Py7h0n wrote:Don't use a earls fitting if you can avoid it. They are overpriced for something that can be done a lot easier.
you can talk mr "I shop at cardwells and pay 4 times the price for fittings"
Users browsing this forum: Bing [Bot], Google [Bot] and 21 guests
