Are 4a-gze rings forged?
Postby Paulio » Wed Aug 26, 2009 2:51 pm
Compared to standard 4ag rings, are gze rings forged or "semi-forged"?
(Toyota genuines)
P
yees booy
Paulio
Postby Bazda » Wed Aug 26, 2009 3:32 pm
Forged???
Is there such a thing?
There are different types as in material.
Postby gasman » Wed Aug 26, 2009 3:52 pm
the rings are usually made from a steel wire so i wouldnt think there would be much variation between non 4agze and 4agze ones apart from maybe the coating or the material if that.
only very very old (~30years ago) piston rings were cast from my knowldege
"What can possibly go wrong?"
gasman
Postby ROBODISCO_20v » Wed Aug 26, 2009 3:53 pm
I think he means chrome top ring. I know ACL ones are.
ROBODISCO_20v
Postby Paulio » Wed Aug 26, 2009 4:27 pm
I.e are they strengthened in any way compared to n/a ones?
Sounds like they arent?
yees booy
Paulio
Postby Bazda » Wed Aug 26, 2009 4:50 pm
You need to ask toyota what material they are made out of, that way you can determine which are better.
If they use different part numbers between them I would stick to what ever the piston is meant to have.
Postby matt dunn » Wed Aug 26, 2009 8:14 pm
Bazda wrote:You need to ask toyota what material they are made out of, that way you can determine which are better.
I believe the GZE ones may have thicker rings?
Anyway, as said use the correct one for the pistons you have,
there may even be different ones for the different models,
MR2, Ae92 AFM, and Map?
Anyway I run genuine toyota AE101 GZE rings for 500hp so they are obviously quite good.
Postby Bazda » Wed Aug 26, 2009 9:14 pm
The early 4agze uses different thickness rings than the later model.
Early model has a 1.5mm top ring, late models 1.2mm top ring.
I also think the oil rings are a different thickness as well.
I think all the late model 4a pistons use the 1.2mm top ring.
Postby TRD_ZERO » Wed Aug 26, 2009 9:30 pm
They are semi forged thats why they are flexible. :roll:
Previous:
TRD_ZERO
Postby Paulio » Wed Aug 26, 2009 9:55 pm
Excelent guys, thats what I wanted to know.
They are flat top forged so obviously 8.9:1 from ae101 gtz, happened to notice a set of rings for these on trademe, what a bonus!
Cheers again
Paul
yees booy
Paulio
Postby IH8TEC » Wed Aug 26, 2009 11:23 pm
wtf, flat top forged rings :?
Postby Bling » Wed Aug 26, 2009 11:29 pm
Pistons maybe..
Postby matt dunn » Wed Aug 26, 2009 11:29 pm
IH8TEC wrote:wtf, flat top forged rings :?
I presume he means pistons.
The AE101 are near flat to look at on the top.
Postby Paulio » Thu Aug 27, 2009 8:57 am
Yes pistons. The difference between the older bigport gze 8.0:1 and the smallport ones I have is pretty clear, hence flat top vs dished.
yees booy
Paulio
Postby CAMB01 » Thu Aug 27, 2009 9:11 am
Most top rings these days are steel, and 2nd rings are usually cast iron.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Bazda » Fri Aug 28, 2009 11:55 am
the 8.9:1 pistons are not flat top.
flat means _______________________
They have a a small -5cc bowl in them.
Postby Paulio » Fri Aug 28, 2009 12:23 pm
Yes I gathered that, I shall reference them as 8.9:1 from now.
yees booy
Paulio
