Lloyd wrote:Shouldn't make any difference what fuel pump you're running as long as its supplying enough to maintain the rail pressure you've tuned the computer for
Jebus wrote:What kind of pumps? if you go from a good 280 pump to a junk 300l/h it might give a lean spot coming on boost if the pump cant provide pressure fast enough.
