ae101 rear wheel bearing, tone wheel?
Postby AE82 FXGT » Fri Sep 11, 2009 7:10 pm
Hey,
I was just trying to replace my rear wheel bearing as it failed a WOF.
All was well until I got the rotating hub+bearing+tone wheel off.
I saw the nut behind the tone wheel, but couldnt figure out how to get the tone wheel off. As a result it is now broken :cry: .
Does anyone know the correct way of taking them off?
And does anyine have another one floating around?
I did a search, and theres mention of them but no instruction...
http://forums.toyspeed.org.nz/viewtopic.php?t=74494&highlight=rear+wheel+bearing
http://forums.toyspeed.org.nz/viewtopic.php?t=45288&highlight=rear+wheel+bearing
http://forums.toyspeed.org.nz/viewtopic.php?t=21816&highlight=rear+wheel+bearing
Thanks
AE82 FXGT
Postby neo » Fri Sep 11, 2009 7:19 pm
neo
Postby Mr Revhead » Fri Sep 11, 2009 8:00 pm
tone wheel? do you mean ABS sensor?
press off usually dont they? maybe with a little heat
Postby AE82 FXGT » Fri Sep 11, 2009 8:24 pm
yeah the bit that rotates for the sensor.
i $&#$% mine anyway, looks like they're meant to press out.
Would anyone know if the lower spec levins (with drums, 5afe) have abs?
I highly doubt it, but it would bail me out a beauty...
AE82 FXGT
Postby Mr Revhead » Fri Sep 11, 2009 10:51 pm
potentially different between disc and drum ones..... not sure but i seem to recall they are. so check carefully first
Postby KinLoud » Sat Sep 12, 2009 8:40 am
I had this when I owned an AE101 GTZ.
My experience... the AE101 ABS "tone" wheel is not designed to be removed.
Toyota repair manual says to replace complete unit! $600 from memory! But check with toyota!
The problem is that the ABS tone wheel is iron and so will crack when you try to remove it to replace the bearing.
Some celicas with abs have a steel ABS tone wheel. It will not crack when you remove it (been there done that).
MAYBE you could carefully machine out the remains of the iron ABS tone wheel from your axle, replace the bearing and then press in a celica steel one (presuming it fits)
OR find a second hand AE101 ABS hub
Ken
Auck
021 408 863
Postby sergei » Sat Sep 12, 2009 9:39 am
I successfully removed ABS wheel off AE111 BZR, drilled the appropriate hole in non-ABS hub and pressed in the ABS wheel in there.
Postby AE82 FXGT » Sat Sep 12, 2009 12:46 pm
Does anyone know how long the shaft is on the wheel?
Im trying to drill it out but dont want to go to far.
AE82 FXGT
Postby Lurkin » Sat Sep 12, 2009 9:11 pm
hmm (re Sergeis drilling out) - so does that mean an abs rear hub (was off an ae101 levin with superstrut suspension) can be used to replace a non abs rear hub (off an ae101 levin with NON superstrut suspension)..
I've had one sitting in the garage but frankly cant be arsed replacing it due to uncertainty of them being interchangeable?
Lurkin
Postby sergei » Sat Sep 12, 2009 10:46 pm
Roy wrote:hmm (re Sergeis drilling out) - so does that mean an abs rear hub (was off an ae101 levin with superstrut suspension) can be used to replace a non abs rear hub (off an ae101 levin with NON superstrut suspension)..
Yes in fact, it was for my mates BZR, he found some AE101 hub on pickapart (he likes to keep thing low budget ;)) and I had the "pleasure" of making it fit. Other than ABS it was straight bolt on.
Postby Lurkin » Sun Sep 13, 2009 7:30 pm
Sergei your a legend - after removing the abs 'cog' it fitted perfectly!! awesome! - but I must say I destoryed the cog in the process...
Lurkin
