Squeaky noise from brakes
Postby loudstealthGT-Four » Sat Sep 26, 2009 10:42 pm
Have had this squeaking sound coming from my front right brake (I think). Only squeaks when driving and really light braking stops when braking normally
When it first started about a month ago I thought oh yea the front pads need changing so I went and bought some new pads and got one side in. But couldn't change the passengers side because the caliper slider was seized but the pads still had meat left on them do just left it as it is. Anyway have pulled the caliper calipers off to check for stones and couldn't find anything and there was no bits that looked like they were scraping on anything. So I'm getting really annoyed because it's driving me mental.
So my question is what could it be??????????????
Rear pads are good
loudstealthGT-Four
Postby Bling » Sat Sep 26, 2009 10:59 pm
So you did nothing about the seized cailper?
Get that fixed if you didn't.
Could be warped rotor, which may or may not be due to seized caliper.
Postby tsoob » Sun Sep 27, 2009 11:43 am
go to a mechanic
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby levinguy » Sun Sep 27, 2009 11:55 am
tsoob wrote:go to a mechanic
if you don't want to learn anything
levinguy
Postby loudstealthGT-Four » Sun Sep 27, 2009 4:16 pm
Sorted my caliper slider this morning but as I thought that wasn't the problem as it is coming from the right side not the left.
Could it be a wheel bearing? Although it doesn't do it under braking???
Going to a mechanic is a last resort or when I completly f#*k it up
loudstealthGT-Four
Postby mr30%jr » Sun Sep 27, 2009 4:31 pm
do what normal people do?
jack the car up and spin the wheels. if you hear it and cant figure out what it is, take wheels off and spin hub, brake caliper etc
mr30%jr
Postby Bling » Sun Sep 27, 2009 5:16 pm
BZG|Bling wrote:Could be warped rotor, which may or may not be due to seized caliper.
Postby tsoob » Sun Sep 27, 2009 9:39 pm
if you do nothing about a siezed caliper and just keep driving, it will be cheaper to go to a mechanic than to "learn" something. or get a mate to help at least
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby THA SHZ » Mon Sep 28, 2009 10:20 am
get the discs machined and make sure that you have all the clips that hold the pads in place , if 1 is missing they can move around and make a noise , but maching would be my first option , or new discs 8)
THA SHZ
Postby Paulio » Mon Sep 28, 2009 10:36 am
check that its not the brake shroud touching the disc, for that matter, check that nothing is touching the rotating parts. if you cant recreate the noise when its jacked up then its going to be a mission to fix it.
yees booy
Paulio
Postby FLAWLES » Mon Sep 28, 2009 1:44 pm
agree
its most likely to be a stone stuck hard up against the disc and the shroud, whip said disc off and clear out the stones
i bet you mr30%jr left nut sack , this will be the cause
FLAWLES
