Factory ECU with daughter board, tunable?
Postby kim0663 » Fri Oct 16, 2009 6:23 pm
This is my ecu I currently use, came from japan like this.
You can see the funny chip thing in this picture
This is my spare ecu. OEM 3sgte ecu.
This picture doesn't have the funny chip thing.
I was wondering if aftermarket chips such as the top picture can be re flashed? As far as I know, the modified ECU doesn't have fuel cut or speed cut and I think it advances timing more as the car drives noticably faster than the oem one.
Mr2 GT-S
330ci M
kim0663
Postby Akane » Fri Oct 16, 2009 7:20 pm
Most likely able to be flashed, but you'll have to send them off to the original maker of the chip most of the time. $$$
Just buy a Powah FC
Postby MR2BOY23 » Fri Oct 16, 2009 7:41 pm
Yeah I've got one of those mines ecu. No fuel/speed cut rev limits at like 8k or something crazy like that and timing is advanced
Need to send it back to them to get re tuned. I'll probably just end up getting the map-ecu2 piggyback
MR2BOY23
Postby kim0663 » Sun Oct 18, 2009 12:44 pm
so has no one on here ever 're-flashed' these chips? looks to be a 36 pin...
Mr2 GT-S
330ci M
kim0663
Postby Akane » Sun Oct 18, 2009 3:45 pm
Nobody has ever bothered to, the cost and trouble sending it to Japan, getting them to tune it to your specs without actually seeing the car, etc...
You can always wire in a Link or somthing and let the factory ECU run the other stuff
