RWD Blacktop
RWD Blacktop
Postby ke_25 » Fri Nov 06, 2009 11:59 am
Hey,
got all the cooling etc sorted for the rwd blacktop block + Head, and now the RWD alternator mount hits where teh auto tensioner goes,
has any one had this problem? i was considering just cutting the rwd alternator bracket to clear, but was unsire of strength? what have other people done?
i would rather run the hydraulik tensioner, changing pump would be a last resort.
Cheers Shaun
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby frost » Fri Nov 06, 2009 1:03 pm
you should of just used the stock blacktop alternator bracket.
Postby hachiroku3 » Fri Nov 06, 2009 6:45 pm
yea, i agree with frost. if you can, just use the blacktop alternator mount. when i did it i just had to space it out with some THICK washers so it matched the same height as where it sits over the rwd engine mount.
hachiroku3
Postby matt dunn » Fri Nov 06, 2009 8:11 pm
I ground away the alt mount to clear on the one i did.
Easy and as long as you dont go crazy it wont affect the strength.
Users browsing this forum: Google [Bot] and 2 guests
