Aristo vvti turbo---4 speed auto?
Postby Coke » Fri Nov 06, 2009 5:53 pm
Looking at a nice vertex 98 Aristo.
Do these have a 4 speed auto?
Are the turbines steel or ceramic from factory?
Anyone have any experience with these cars?
Coke
Postby ihavelift » Fri Nov 06, 2009 8:09 pm
really good cars mate, so economical for what they are, comfortable as all hell but they haul arse when the need to. Typical toyota reliabilty, can't go wrong with them. sweet $&#$% rides
Current: 2000 Honda Accord Wagon CF6
Previous: 97 Toyota Celica GT4 ST205; 2001 Toyota Allex RS180, 96 Nissan Sentra SG
Low, Slow, Clean and Mean
ihavelift
Re: Aristo vvti turbo---4 speed auto?
Postby Phothog » Fri Nov 06, 2009 8:35 pm
Coke wrote:Are the turbines steel or ceramic from factory?
The 1jz VVti turbos i have seen have had ceramic turbine wheels.
Chris.
1999 ST215W GT-T 325,000kms still going strong.
2000 M201G YRV Turbo, 1300cc little pocket rocket.
Need a Turbo Rebuilt or Upgraded... send me a email Chris @ Turbo.co.nz
Phothog
Postby ~SlideWays~ » Fri Nov 06, 2009 9:07 pm
ihavelift wrote:really good cars mate, so economical for what they are, comfortable as all hell but they haul ar*e when the need to. Typical toyota reliabilty, can't go wrong with them. sweet $&#$% rides
How economical? I've been thinking about simething with a 2jzgte.
I can't imagine such a big car plus auto (probably) would get near 10k's per litre would it?
~SlideWays~
Postby FLAWLES » Fri Nov 06, 2009 9:31 pm
Chris.
can confirm this two fold.............have my old one thats if naffed and a spare ct15b thats naffed ( 1jzgte vvt-i )
im 50% sure that the vvt-i 2jz turbos are ceramic, from what i have herd, but in saying that the turbos seam to be different between both gen 2jz's, part number wise, so maybe...........lol pull one apart hahaha
but look here
jzs161 ( vvt-i 2jz )
http://www.toyodiy.com/parts/p_J_2002_T ... 701.3.html
jzs147 ( 1st gen 2jz )
http://www.toyodiy.com/parts/p_J_1995_T ... 701.3.html
the a340e trans are bulit proof man, and can handle alot of abuse and HP, even more so when you shift kit them and or "up the line pressure" so they say
FLAWLES
Postby ihavelift » Fri Nov 06, 2009 9:53 pm
I can't give you an exact figure, but on open road the figure drops below 10, around city is a bit more but still a lot more economical than you'd expect. All that low down torque is a real plus in the economy department
ihavelift
Postby Jason T » Fri Nov 06, 2009 9:54 pm
Coke wrote:Looking at a nice vertex 98 Aristo.
4 speed paddle shift drives like a manual
turbines are ceramic .9 bar stock same basic set up as first gen
ihavelift wrote: Typical toyota reliabilty, can't go wrong with them. sweet $&#$% rides
Bad points = lower arm suspension bushs & ball joints 2 pot fronts brakes
~SlideWays~ wrote:How economical? I've been thinking about simething with a 2jzgte.
7.2 town with 98 bp 11.5 open road legal speeds Big car with 1600+kg to stop
Some good info here http://www.clublexus.com/forums/gs-second-generation-184/
Fixing Toyota's since '87
Jason T
Postby Py7h0n » Mon Nov 09, 2009 9:34 am
Just be warned the brake system is extremely expensive to fix if it goes wrong.
Py7h0n
Postby the fallen303 » Mon Nov 09, 2009 10:37 am
do the 161's still run the nitrogen setup like the turbo 147's? i'm going to look into converting my 147 to the normal vacumn setup from my parts car and spares from dads mk4, haha.
bw jason did you say the 147's run .9 bar boost? ours only runs .67 :?
true house of JZ
Stay true to the origin
the fallen303
Postby FLAWLES » Mon Nov 09, 2009 12:07 pm
are the a340e trans on the jzs161's paddel shift?
if so that is sweet
FLAWLES
Postby Coke » Mon Nov 09, 2009 12:55 pm
Thanks for all the input guys.
The brakes are weird but may have been adjusted? The dude that used to own it was apparently 6'6 tall. There is alot of travel before there is any kind of engagment. Not mushy or sloppy just takes a bit to get them to work.
Any thoughts?
Coke
Postby FLAWLES » Mon Nov 09, 2009 1:01 pm
pads, check the front and back ones
most likely worn
and give the fulid a once over/change
you will find that once you change these things the pedal feel will be 100 times betterererrrr
FLAWLES
Postby Crampy » Mon Nov 09, 2009 4:05 pm
Nice dude. I want one of those as well.
How much are you getting that one for?
They are 4 speed autos and as stated they are paddle shift (well buttons on the steering wheel)
From what I've read they are ceramic turbos.
Some specs here:
http://www.cars-directory.net/specs/toy ... 998_8/515/
Crampy
Postby Jason T » Mon Nov 09, 2009 4:43 pm
the fallen303 wrote:do the 161's still run the nitrogen setup like the turbo 147's? i'm going to look into converting my 147 to the normal vacumn setup from my parts car and spares from dads mk4, haha.
JZ161's have upgraded to a more expensive to repair electrics system no more nitrogen setup
My JZS161 runs .9 bar stock
Paddle shift drives as good as a manual
Car porn http://www.youtube.com/watch?v=0Fvs4LL7n88
Coke wrote:Thanks for all the input guys.
Any thoughts?
Yep has no "feel" to pedal but stops damn well
Jason T
Postby Crampy » Mon Nov 09, 2009 4:58 pm
Buy one then slap on a T04Z:
http://www.youtube.com/watch?v=s4-5dJjcj2U
"woo hoo, holy $hiiiiit!"
Crampy
Postby ihavelift » Mon Nov 09, 2009 6:48 pm
which one on trade me is it? blue one with 20s? if so that's a SICK car, if you don't do it then you should hang your head in shame haha.
ihavelift
Postby 4bid1n 2jz » Mon Nov 09, 2009 9:25 pm
Coke wrote: There is alot of travel before there is any kind of engagment. Not mushy or sloppy just takes a bit to get them to work.
i have this problem in my supra must be about 40mm of travel then they work good and brake fluid has been changed
jzs161 aristo 2jzgte vvti
projects
townace van 3tgte
ke35 sr coupe
and a turbo starion
4bid1n 2jz
Postby Makaveli » Tue Nov 10, 2009 7:11 pm
Aisin A340E 4 Speed Auto. I think only V300 Vertex comes with Paddle shifters and also it comes with four wheel steering as well. Some buy Tom's lock bar to disable the rear wheels turning. They don't come with LSD. They have plenty of torque from low down. Turbos are most probably ceramic, same as JDM supra. I believe on US Spec supra came with steel. I don't see the point in screwing around with upping the boost and damaging the turbos as such. They are a nice VIP cruiser with plenty of power from factory.
There is a nice blue one on trademe. V300 Vertex with full leather.
Brake pedal travel could be normal. I have the same thing with my Celsior. They have a bit of travel, this is normal as have been verified by Toyota. So that Aristo might have the same thing. Could be normal.
Makaveli
car
Postby docTRD » Tue Nov 10, 2009 10:19 pm
Hey Armin howsit man, geez stepping up a bit from the old auto supra then ay going to some turbo grunt :) did u sell ur mk4?
Daily : st191 corona liftback mmm room
Project : Jzx90 mark2 Tourer V
--- wtd: corolla GT ae92 sedan ---
"Mum i knw its another wreck, i only got it so i can put the seats in the lounge" YEAH RIGHT
docTRD
Mo Joe
