ke25sr wrote:I have had my diff shortened and the axles shortened and re splined
When resplining they had to build up the axle because the spline steps up.
The weld had mad the splins soft and it broke ver clean and very straight, didnt even make a noise.
So what are my options?
i dont want to do the same thing again and get the same problem
Billett axles?
axles from another car that can be modded to work?
ideas please
Burning Angel wrote:if they build them up with the right filler material, once its been resplined you can get them heat treated to bring it back to spec.
i imagine billett axles would be prohibitively expensive as you'd need to start with a blank the same size as the flange.
NZ_AE86 wrote:In wellington I get them made by a machine shop called
http://yellow.co.nz/whitepages/Naenae/Howat-Industries-Limited/101238005_BUS.html
I have not got any made for a few years but spoke with him about making some 2 weeks ago, I was told $2-300 each, he also said it depends on the price of steel when he buys it. He heat treats them and uses your exsisting flanges. He makes axles for a lot of local sprint cars (high HP dirt oval type of thing).
AE25 wrote:i was quoted $180 and $200 each axle from steelie gears and diffs'r'us respectively for shortening and resplining about 6 months ago.
very curious how the flange is attached and held on?? got pics?
NZ_AE86 wrote:AE25 wrote:i was quoted $180 and $200 each axle from steelie gears and diffs'r'us respectively for shortening and resplining about 6 months ago.
As far as I know at the factory they are attached just like a ring gear - heated then fitted. When Brian (axle maker!) fits them to the new axles he puts a small weld on the outside. He can also make new flanges if yours are damaged, you can't supply some or if you want to change stud pattern or something.
Oh and if you do use him can you let him know how you got on to him.
