AE111/101/92 rear strut - aftermarket insert problem
Postby KinLoud » Wed Mar 31, 2010 10:44 pm
OK - i have an AE111 wagon. I want to put my trd adjustable strut inserts into the rear struts...
BUT
I can seem to find any rear struts that have a threaded tube, they all seem to be welded ones? (I look everytime I go to pick a part)
Does anyone know if threaded ones exist?
Or should I just find a suitable diameter threaded top and get it welded on to a strut?
I found a threaded one for the front strut no problem at all!
Thanks
Ken
Auck
021 408 863
Postby TRD Man » Thu Apr 01, 2010 12:04 am
There were some, but very few, standard rear struts with screw tops.
Most floating around now will be aftermarket housings.
I might have some here but if you can't find any you can cut the top off the sealed ones and weld on a screw fitting.
TRD Man
Postby KinLoud » Thu Apr 01, 2010 7:58 am
Thanks for that info - yeah cut and weld is probably where I will go.
But if I can find threaded ones it will be way simpler
Threaded ones - were they nz new only or JDM also?
Thanks
Ken
aUCK
021 408 863
Postby Bazda » Thu Apr 01, 2010 8:56 am
Most likely from an earlier model ae series.
ae92.. my ae92 stock gtz had threaded ones..
Postby Mr Revhead » Thu Apr 01, 2010 7:16 pm
My preface lift AE101 Levin had threaded tops. Shouldn't be too hard to find some 2nd hand ones of those.
Just check out the brake hose bracket
