so went to pick a part and found the st206 curren ones and they bolted up fine and also allowed me to keep the ss disc at 273mm.
AE25 wrote:so went to pick a part and found the st206 curren ones and they bolted up fine and also allowed me to keep the ss disc at 273mm.
could someone clarify what is used here... some sort of caliper bracket that fits twin pots to the ae uprights? or the calipers themselves or was it the st206 uprights.
Mr Revhead wrote:So you bolt on the St2## calipers with 3mm spacers and they fit perfect?
AE25 wrote:ah so twinpot (single side) st2## caliper fit on ae strut (non s/s) to fit s/s 275x25mm disk. sounds overly generalised to cover all caliper/disk combinations. is it only the twinpots that have an original 275x25mm dia disk that fit? or from any particular disk size on the original st20# car?
doubt these pickapart st205 calipers will fit my ae82. um.. originally 315x32mm disk ish?? heh
