I need to fit a pair of ae92 rear shocks to an ae82 but the bolt spacings are different.
AE82 rear suspension
ae92 rear suspension
these the parts required to do ae92/ae101 conversion..
ae101 dust shield (yes it's a separate part)
ae101 rear hub (55mm locating hole for disk but steps down to 54mm for wheel)
ae101 rear disk 266 x 9mm
ae101 rear caliper
ae92 strut
ae92 spring
ae82 spring cap
ae92 upright/knuckle (the hub bolts to it)
ae92 trailing arm outer bush modified shorter to 40mm wide (fits in the ae92 upright)
ae82 brake hose (ae101 brake hose doesn't fit the ae82 chassis mounting bracket).
ae82 (disk type) hand brake cables
14" or larger wheels
Bazda wrote:The ae82 hole is narrower by approx 10mm.
So to me the easiest way is to elongate the hole 10mm.
