Who knows their Caldina's??
Postby crispy'86 » Thu May 13, 2010 1:31 pm
Wondering if the steering rack and column or maybe just the rack from an ST215 or similar model would fit out ST191 caldina?? Maybe an ST205 or similar are the same or different. And what about if the crossmembers are exactly the same or not/
crispy'86
Postby strx7 » Thu May 13, 2010 6:33 pm
from my knowledge of toyota steering racks the ST215 rack will have differen fittings on it as it is a 4wd. and an ST191 is a 2wd.
there should be sh1t loads of st190/st191 caldina/corona steering racks around christchurch.
Postby crispy'86 » Thu May 13, 2010 7:21 pm
Yes i know they are both different but i was hoping they'd be interchangeab;e between the models. Also would an st190/1 corona steering rack and crossmember be eactly the same or are they different due to having different length steering columns? The logic in me says they are the same/ similar chassis codes so i can't see any difference, though i don't want to buy the bits to find they are slightly different
crispy'86
Postby fivebob » Thu May 13, 2010 10:32 pm
The rack from the ST191 is the same part # as the ST190,191/AT190,191/CT190/ST210/AT211. Also same as the Carina/Corona of those model as well as Gaia,Nadia & Ipsum(SXN15/SXM15).
Postby crispy'86 » Fri May 14, 2010 7:30 am
Cheers, that should narrow at least one search for parts down :)
crispy'86
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
