Heater Mixing and Auto climate Problem
Postby micah211 » Mon May 17, 2010 11:05 am
I have a 97 BZ Touring corolla and the heater does not mix. Its either cold or hot and nothing in between. Also the auto function on the blower does not work, it just blows at full. The blower is fine from low to high. Im sure itis a fairly simple part to replace but cant find any info on which part it is. Any idea's?
Micah Hetrick
BZ Touring Corolla
Love that 4-age!
micah211
Re: Heater Mixing and Auto climate Problem
Postby sergei » Mon May 17, 2010 11:42 am
micah211 wrote:I have a 97 BZ Touring corolla and the heater does not mix. Its either cold or hot and nothing in between. Also the auto function on the blower does not work, it just blows at full. The blower is fine from low to high. Im sure itis a fairly simple part to replace but cant find any info on which part it is. Any idea's?
Most likely the cabin temp sensor is disconnected.
On corollas it is under the steering wheel, above clutch pedal, in the panel you will see a little window, behind that there is a sensor. Somebody disconnected it when they did something like alarm install or other work.
Postby sergei » Mon May 17, 2010 11:46 am
Postby sergei » Mon May 17, 2010 11:48 am
If that is not disconnected, possibly the front one (ambient temp. sensor) could be disconnected, but I am not sure if it will have same effect.
Postby micah211 » Mon May 17, 2010 1:08 pm
Thanks for the help. Will this solve not being able to mix hot and cold? At the moment i either have cold or well hot
Micah Hetrick
BZ Touring Corolla
Love that 4-age!
micah211
Postby sergei » Mon May 17, 2010 1:20 pm
micah211 wrote:Thanks for the help. Will this solve not being able to mix hot and cold? At the moment i either have cold or well hot
This should fix that and auto function as it is related.
Postby micah211 » Mon May 17, 2010 1:54 pm
Wicked thanks for that. I will give it a Go!!!
Micah Hetrick
BZ Touring Corolla
Love that 4-age!
micah211
