Oil Pressure warning light flashes for 2-3 secs at startup??
Postby Tha_INS » Fri May 14, 2010 9:40 am
Hi guys its not a toyota but I just did an oil change on the mrs 97 Nissan Bluebird and the oil pressure too low warning light always flashes for a few secs now when starting from cold. If its been warmed up it doesn't do it any suggestions on what I should do next?
Engine is an sr18de and oil is Valvoline Durablend 10w-40, oil level is just below full mark on the dip stick when on a level surface if that helps.
Tha_INS
Postby MR2BOY23 » Fri May 14, 2010 10:39 am
What sort of oil filter are you using?
Where is it mounted? I don't know much about these engines.
Also try a 15w-40 next oil change that should help
MR2BOY23
Postby strx7 » Fri May 14, 2010 11:35 am
as soon as i read the thread topic i thought, bet its and SR......
Postby AE82 FXGT » Fri May 14, 2010 8:01 pm
Yeah a good oil filter (factory) and the correct weight oil (a bit heavier when cold, then what you have) should do the trick.
AE82 FXGT
Postby Alex B » Fri May 14, 2010 8:21 pm
strx7 wrote:as soon as i read the thread topic i thought, bet its and SR......
Real? I thought gen 2 3S :lol:
Postby Bling » Fri May 14, 2010 9:43 pm
MR2BOY23 wrote:Also try a 15w-40 next oil change that should help
What are the facts behind this helping?
Postby Tha_INS » Fri May 14, 2010 10:02 pm
just using a ryco oil filter will try using a heavier weight oil but had an online service manual for it which stated it takes 10w-30.....
filter is mounted on the side of the block on the intake side
Tha_INS
Postby frost » Fri May 14, 2010 10:16 pm
check if the oil filter has anti oil drain back, or buy a new one with it,
my 4age did this when i fitted the wrong filter without anti drain back, it stayed on for longer then normal so i got worried and swapped to toyota filter and it goes out just like before,
Postby MR2BOY23 » Sat May 15, 2010 2:02 am
If he's using a a cheap filter without an anti drain back valve that could be the issue
a 15w is thicker on startup so that could also solve the issue
majority of cars pre 2000 should be using 15w-40 anyway
MR2BOY23
Postby CAMB01 » Sat May 15, 2010 4:17 pm
What is the engine like inside?
Has it been regularly serviced?
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Tha_INS » Sat May 15, 2010 9:03 pm
have not taken engine apart but its tidy
Tha_INS
Postby AE82 FXGT » Sun May 16, 2010 3:37 am
Tha_INS wrote:have not taken engine apart but its tidy
I imagine CAMB01 would mean a quick look under the rocker cover, not taking the engine apart. If it clean under there, its safe to assume the motor itself is pretty clean. If it full of gunk however...
AE82 FXGT
Re: Oil Pressure warning light flashes for 2-3 secs at start
Postby allencr » Sun May 16, 2010 4:18 pm
Tha_INS wrote: I just did an oil change...
It has either always worked this way and it is just your imagination, or it is getting ready to die & there isn't a thing you can do.
Just drive it.
allencr
Postby iOnic » Sun May 16, 2010 5:12 pm
Or oil is draining out of the oil filter when it's left sitting so it takes longer than it should to build oil pressure? :roll:
Postby frost » Mon May 17, 2010 2:29 am
the most damage is done at start up so this is one of those fix it right things,
genuine oil filters only.
Postby sark.inc » Tue May 18, 2010 7:37 pm
a ryco filter is just as good as genuine imo.
Could be a faulty oil pressure switch or oil pump.
sark.inc
Postby frost » Wed May 19, 2010 12:39 am
depends where it was made,
