KE25-KP30 wrote:Hey guys,
Just toying up ideas for a 1KZ-TE swap and wondering if anyone has had any experience with wiring them up etc? Have they got any funky stuff going on? i.e Will they go easily enough into something that's already diesel? No special fuel pumps or what not? Plan would be to stick with stock auto trans also.
Cheers,
Kent
Conversion will be similar to for an petrol EFI engine swap, the only thing that you don't need to modify fuel lines or anything fuel tank related.
The KZ will have extra wires and loom, as well as ECU. The fuel pump is on the engine, it can also be converted to manual pump (pricey and not really an advantage).
