Headgasket was fine.
Water pump was fcuked
Replaced
Now all spiffy
MAGN1T wrote:Murphy's law says that the last headgasket job done on the car wasn't done properly.
Needs doing again.
Too much pressure blows the coolant our through the seal.
Steve
Burning Angel wrote:MAGN1T wrote:Murphy's law says that the last headgasket job done on the car wasn't done properly.
Needs doing again.
Steve
are u saying i don't know how to change a headgasket?
and even if that were true the cooling system could only be pressurized as much as the radiator cap will allow(15psi or so) therefore could not blow the seals on the pump, which aren't even rubber.
