option for caldina o2 sensor
Postby speedracer07 » Thu Jun 17, 2010 11:02 am
Does anyone one know of any other toyota car o2 sensor's that work in the st-215 3s-gte? I think I need a new o2 sensor and sourcing this part locally 89465‑21030 would be difficult.
alternatively does anyone know of a denso part number or universal part number that will work?
thanks!!
Roshan
SW20 with ST215 motor (fivebob is my hero)
speedracer07
Postby BZG Wagon » Fri Jun 18, 2010 6:29 am
I had a mate rebuid mine after the vechicle testing dude broke it. They come apart fairly easy, & not hard to soilder.
Other than that I hear they are a standard part across most toyota models so wouldn't expect one to be hard to find.
BZG Wagon
Postby speedracer07 » Sat Jun 19, 2010 1:34 am
that's what I figure'd but I was wondering about the resistance readings that sometimes vary between o2 sensors (or so I understand?)
The Caldina O2 sensor screw's in so would the universal denso one's work without modification? The mr2 one's have a flange and 2 bolt's.
speedracer07
Postby BZG Wagon » Sat Jun 19, 2010 10:28 am
I was worried about resistance changes after soildering the sensor, but after connecting the car to a scan tool all the readings were in line with expectations.
I'd suggest you just try it - you'll know fairly quick whether it works or not.
I'd suggest resetting the EFI once you do it too.
BZG Wagon
Postby Bling » Sat Jun 19, 2010 2:02 pm
We have a Toyota sponsor on the board, you could email them as they may be able to source you one and get it sent out your ways.
viewtopic.php?t=66290
Postby NZ_AE86 » Tue Jun 22, 2010 3:07 pm
You should never solder any connections on an Oxygen Sensor!
A Bosch sensor "0258986617" will do the same job for this aplication.
If you PM me you Email I can flick you a PDF list of toyotas that use the same sensor.
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby speedracer07 » Thu Jun 24, 2010 5:55 pm
NZ_AE86 wrote:You should never solder any connections on an Oxygen Sensor!
thanks!! sent pm
speedracer07
