Transmission oil cooler for engine oil
Postby cat007 » Sat Jun 26, 2010 5:05 pm
Is there any reason why using a transmission oil cooler as an engine oil cooler would be bad?
I've got one of these:
Postby pureadrenalin » Sat Jun 26, 2010 5:41 pm
No, they are mostly designed for the same pressures, but transmission coolers normally have alot less flow so the inlet/outlet/piping tends to be smaller.
If you are happy with the size of the tubing on it, go for it. If its too small it will create more pressure drop.
pureadrenalin
Postby cat007 » Sat Jun 26, 2010 5:55 pm
Thanks for that. I'll check the fittings and see if they'll suit.
Also in regards to mounting it, would it pose a problem if I attached it to the front of the intercooler? Or should I think about putting it elsewhere?
Postby frost » Sun Jun 27, 2010 1:17 am
don't do it, there trans coolers for a reason, other wise they'd be called trans/engine coolers,
basically there far too small for engine oil flow,
Re: Transmission oil cooler for engine oil
Postby allencr » Sun Jun 27, 2010 3:25 pm
Notice how it's one continuous piece of pipe, meters/yards long compared it one for oil that has many paths from the inlet to outlet. A log manifold in & out with a dozen or more narrow tubes in between. The narrow tubes may seem smaller but they have much more surface area to be able to dispose of more heat faster.
allencr
Postby CelicaGT8 » Tue Jun 29, 2010 3:22 pm
Your engine wont like you
CelicaGT8
Postby coupekiwi » Tue Jun 29, 2010 4:36 pm
I lold
Do it.
coupekiwi
Postby cat007 » Tue Jun 29, 2010 4:37 pm
Well in that case. Anyone wanting to buy a transmission cooler :P
