ee904age wrote:Im not sure about gearing, but I would guess the the shorter wheelbase of a Familia would require a custom driveshaft anyway. Why not just leave the stock GTR rear end in there??
angryface wrote:Good info you guys, thanks.
For axles, ST185 and ST205, I heard that they're interchangeable in a ST185 gearbox. I haven't found anything about the hubs, do the hubs from both generations accept the same diameter + spline count axle?
Anth_555 wrote:from what i been told the st205 run a wider wheelbase then st185 , with longer drive shafts are you using celica hubs or mazda hubs?
Scottie wrote:angryface wrote:Good info you guys, thanks.
ST205 front axles are longer than ST185/165 items. Splines are the same.
Rears I am unsure about. Can check tomorrow.
fangsport wrote:is this road or rally use??
this is quite a common alternative to using the $pendy X-trac unit in Europe .
unsure how many dead GTX/GT-R boxes i have seen due to there weak casings causing the gears to climb out of mesh.
so the gt35 blows through the gt28 and then feeds the engine correct?
are you going to intercool the charge between the turbos or after the two turbos? or both
