indicator works but doesnt flash
Postby gleem » Fri Jul 16, 2010 12:42 am
i presume its a relay? but it died slowly and worked properly on and off which makes me think its in the leaver somehow. Were are the relays normally? Rav4 lol
gleem
Postby RobertC » Fri Jul 16, 2010 1:16 am
the relay should be on the rh side of the drivers footwell. have a look at here on the left of the image it shows the flasher relay. It says flasher and is represented by a circled 4.
Working on and off could be corrosion? So just pull it out and check.
RobertC
Postby Boosted_162 » Fri Jul 16, 2010 9:13 am
Blinker fluid is low.
Postby gleem » Fri Jul 16, 2010 10:19 am
thanks. I pulled it out and put it back on and it works fine. no corrosin. Were do you find websites/maps like that? i search or so pages in google and nothing like that came up
gleem
Postby 1I1 » Fri Jul 16, 2010 10:48 am
TRD Clicky >>Here
1I1
Postby RobertC » Fri Jul 16, 2010 10:51 am
gleem wrote:thanks. I pulled it out and put it back on and it works fine. no corrosin. Were do you find websites/maps like that? i search or so pages in google and nothing like that came up
That website is pretty much an online version of toyota EPC. Just click where it says my cars then click add new. Click japan, year and so on. It covers all Toyota.
RobertC
Re: indicator works but doesnt flash
Postby 85AW20v » Sat Jul 17, 2010 9:32 am
Can't see what the problem is myself......
gleem wrote:.... and worked properly on and off ....lol
But the subject line confused me a bit - if it doesn't flash it doesn't work :!: :!:
Sorry - couldn't resist it.
See ya
Simon
85 MR2 20v
85AW20v
