delay before car starts?
Postby .:O4AGTZ:. » Sun Aug 08, 2010 4:35 pm
Well its a 91 corona, my GTZ used to do as well sometimes. Well bascially you turn the key to start it and you sort of hold it there for 3-5 seconds before it actually tries to start. Any idea was this could be?
.:O4AGTZ:.
Postby Lloyd » Sun Aug 08, 2010 4:44 pm
Contacts in the key, starter contacts....
Postby .:O4AGTZ:. » Sun Aug 08, 2010 6:00 pm
hmmm okm couldnt be anything to do with battery? all power is there though and batery appears fine
.:O4AGTZ:.
Postby Quirky » Sun Aug 08, 2010 7:34 pm
Starter motor contacts.
Ive got the same problem.
Hello There
Quirky
Postby .:O4AGTZ:. » Sun Aug 08, 2010 9:02 pm
ah i see. will check those first. gotta do cambelt and service soon so will do it then
.:O4AGTZ:.
Postby matt dunn » Sun Aug 08, 2010 9:53 pm
I would say voltage drop to the starter operating terminal.
A starter overhaul may fix it for a while, but a starter relay will fix it for good.
