Clutch Pedal Dropping
Postby xno37 » Tue Aug 31, 2010 4:02 pm
The clutch take-up in my sisters car has dropped to the floor about 4 or 5 times recently. I've looked through the clutch line and it doesn't seem to be leaking anywhere, and the reservior hasn't moved at all. Bleeding the clutch fixes it temporarily, but next time the car is used take-up is at the floor again.
Would the problem be with the master or slave cylinders? If so how do I go about checking them?
Car is an 94 Corolla 4afe-c52, and only gets driven once or twice a month.
xno37
Postby tsoob » Tue Aug 31, 2010 4:59 pm
yes it will be a problem with those if the lines are all good.
take it out of the car and take it to abc in takapuna
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
