20v questions
20v questions
Postby gmacrae » Thu Sep 16, 2010 10:20 am
I've got a good blacktop head/intake i'm gonna put a on my silvertop soon and just have a couple of questions about it. The car is already running the blacktop ecu/loom.
1) Is the blacktop head/valves compatible with the cutouts in the silvertop pistons? ie will it still be non-interference?
2) What will the resulting compression ratio be like?
3) I assume the silvertop head gasket is the same as blacktop?
4) anything else I should know?
5) I'm after a blacktop exhaust 2-1 section and blacktop front/cambelt covers - anyone got this stuff to sell me?
Cheers lads
Gene
gmacrae
Postby Flannelman » Thu Sep 16, 2010 12:13 pm
Answers
1) Yes.
2) About 10.2 to 1 at a guess. Will be less as the blacktop has larger combustion chamber.
3) Yes.
4) Have you got the blacktop plenum? If not the silvertop one can be drilled to acept the backtop throttle bodies.
5) Sorry cant help. I should get a welder and start making headers...
Flannelman
formerly known as Affroman
Postby touge_ae101 » Thu Sep 16, 2010 12:38 pm
TBH with respect to the headers, it is probably best only get the 4-2 section of the blacktop headers as they are a bit better than the silvertop and get a 2-1 section made up as the blacktop 2-1 section is shit.
@affroman - i would like to see someone make cheap headers for blacktop, mine cost me about $400 in materials and argon. not exactly a bargain still.
touge_ae101
Postby KinLoud » Thu Sep 16, 2010 12:43 pm
I make it 9.9 to 1 from my measurements
Ken
Postby rollaholic » Thu Sep 16, 2010 4:46 pm
blacktop pistons required imo, 9.9 is shit!
Postby gmacrae » Thu Sep 16, 2010 6:01 pm
rollaholic wrote:blacktop pistons required imo, 9.9 is shit!
im with ya on that one - dont want low compression... might just make up a decent fresh block and swap the lot in.
I've got a good blacktop block and pistons, but crank and rods are buggered... anyone got a good set of silvertop rods and crank they wanna sell me? not interested in anything with spun bearings
gmacrae
Postby sark.inc » Thu Sep 16, 2010 6:35 pm
just use your current silvertop rods? and put the blacktop pistons in.
sark.inc
Postby Bling » Thu Sep 16, 2010 7:41 pm
gmacrae wrote:crank and rods are buggered...
:lol:
Postby gmacrae » Sat Sep 18, 2010 1:12 pm
sark.inc wrote:just use your current silvertop rods? and put the blacktop pistons in.
yea i would but cant really afford much down time with that car, basically needs to be done in a weekend... engine out, engine in kinda thing
gmacrae
