Prob with pk1865 fanbelt not fitting aircon delete 1jzgte
Postby drift-monkey » Fri Sep 24, 2010 9:37 am
I cant for the life of me get this belt to fit, does the tentioner move to allow to chuck it on? cause i was trying to whench it but it wouldnt move at all? its non hydro waterpamp dont know if the pullys are different size or something? any sugestions?
drift-monkey
Postby Quint » Fri Sep 24, 2010 10:35 am
Tensioner should be adjustable. (is on the 1g)
Quint
Postby Jebus » Fri Sep 24, 2010 11:23 am
14mm ring spanner on the bolt that holds the plastic pulley, turn it clockwise and the tensioner will move downwards. Might just be sticky
Jebus
Postby MrOizo » Fri Sep 24, 2010 12:28 pm
i thought it was a 1900 that was needed. i am sure my stock one was 1940
MrOizo
Toyspeed Legend
Postby Looonie » Sat Sep 25, 2010 9:53 am
6PK1865 is what I've used on the 1JZ-GTE with no air con.
Just make sure you're routing it correctly. Off the top of my head it gets routed in a backwards C-pattern starting from the crank pulley with lower going up to PS pulley and across to water pump pulley, upper going around tensioner and down to alternator pulley. If that all makes sense.
As Jebus said, 14mm ring spanner (longer the better) on the tensioner pulley bolt and push it down to compress the tensioner, slip the belt over the pulley and release the tension.
Rumple dee pumple dee doo...
Looonie
