Fuel gauge needle problem
Postby coolnik12 » Thu Sep 23, 2010 7:48 pm
Hey guys i own a 1996 Trueno and i have been noticing that when i fill up fuel in my car, it takes pretty long for the needle to actually come up to the right level and then it drops down pretty fast hence not doing enough amount of kms.
Also halfway between the last line and the second last line the reserve light goes on :o i drive it till the end anyways but what do you guys think the problem is??
coolnik12
Re: Fuel gauge needle problem
Postby metal_sean_head » Thu Sep 23, 2010 7:56 pm
coolnik12 wrote:Hey guys i own a 1996 Trueno and i have been noticing that when i fill up fuel in my car, it takes pretty long for the needle to actually come up to the right level
I think this is normal. This is what my FX does.
How many kms are you getting to a tank?
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby Quirky » Thu Sep 23, 2010 8:06 pm
Normal, the petrol tank isnt an even square shape.
In my case 300km to half and then 100km to empty.
Hello There
Quirky
Postby touge_ae101 » Thu Sep 23, 2010 8:12 pm
+1 can confirm this is normal.
few dents in the bottom of the tank doesn't help though...
touge_ae101
Postby coolnik12 » Thu Sep 23, 2010 8:16 pm
Im doing about 310 kms to a full tank, driving in the city. I know im supposed to do more than that!!
coolnik12
Postby duddley » Thu Sep 23, 2010 8:19 pm
how many litres are you putting in each tank tho?
i don't club seals..... only sandwiches
duddley
Postby touge_ae101 » Thu Sep 23, 2010 8:20 pm
depends on a lot of things really though.
- have you got fresh spark plugs?
- have you cleaned your throttle bodies recently?
- have you replaced oxygen sensor?
- have you checked timing?
mine does (did) about the same km's on the open road and that was 20degrees advanced timing so hopefully i'll get a bit more out of it now :lol:
touge_ae101
Postby coolnik12 » Thu Sep 23, 2010 8:25 pm
duddley wrote:how many litres are you putting in each tank tho?
I think its about 40 litres to a full tank
coolnik12
Postby coolnik12 » Thu Sep 23, 2010 8:26 pm
touge_ae101 wrote:depends on a lot of things really though.
Got new spark plugs, havent cleaned the throttle bodies or the sensor. How much would it cost to change the oxygen sensor??
coolnik12
Postby touge_ae101 » Thu Sep 23, 2010 8:33 pm
squillions!
well maybe not, but email our sponsor mark at toyota and he'll get you a sharp price but they aren't cheap. but no point buying non-genuine its just not worth it.
touge_ae101
Postby h8wrxs » Thu Sep 23, 2010 9:40 pm
mm my both truenos ive had , (and gtz levin actually) have done around 300km in top half then only about 100-150km on the bottom half of the gauge
The four seasons in Australia consist of "$&#$% it's hot", "Can you believe how $&#$% hot it is?", "I won't be in today because it is too $&#$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Postby coolnik12 » Thu Sep 23, 2010 9:41 pm
h8wrxs wrote:mm my both truenos ive had , (and gtz levin actually) have done around 300km in top half then only about 100-150km on the bottom half of the gauge
Mine does 320kms in a full tank. Full tank would be 35 litres. Its definately doing less k's
coolnik12
Postby eskimo » Thu Sep 23, 2010 9:54 pm
I get 450 to a tank around town(auckland traffic 5 days a week) 300kms to the first half and 150 to the second half. Thats running BP98 in my AE111
I replaced my oxy sensor with a TGP one about 6months ago as I was only getting 360-80kms to a tank so it is worth replacing
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby coolnik12 » Thu Sep 23, 2010 10:21 pm
eskimo wrote:I get 450 to a tank around town(auckland traffic 5 days a week) 300kms to the first half and 150 to the second half. Thats running BP98 in my AE111
How much was the sensor? Where did you get it done from?
Cheers!
coolnik12
Postby eskimo » Thu Sep 23, 2010 10:28 pm
Sensor was $210-220 from memory. Email Mark our sponsor and he will be able to source a TGP one for you
eskimo
Postby CAMB01 » Thu Sep 23, 2010 10:57 pm
I used to get between 550km and 600km from a tank of 98 in my old 20v Levin.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby coolnik12 » Thu Sep 23, 2010 11:05 pm
CAMB01 wrote:I used to get between 550km and 600km from a tank of 98 in my old 20v Levin.
Thats heaps dude! Really need to get under this and find out the main cause!
coolnik12
Postby tsoob » Tue Sep 28, 2010 11:29 pm
i sometimes get 300ks to a tank... sometimes :twisted:
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby neo » Wed Sep 29, 2010 11:26 am
my old on got between 300 and 400 km a tank.
replaced the AFM and it got good midrange + 480- 420 a tank around town.
I admit however I drove it like a convict, and spent alot of time going up and down steep hills .
neo
