ae85 dash loom?
ae85 dash loom?
Postby Nizbit » Tue Sep 28, 2010 10:43 pm
hey guys, i have a few wires that i need to transfer to the sr20de loom,
just wondering if anyone has the pinouts or the diagrams to show me what they're for,
Nizbit
Postby frost » Tue Sep 28, 2010 10:58 pm
the long green one is for emissions control ecu, can be unplugged without any ill effect,
you can find a useful.....
speed signal
rpm signal
batt+ and 12v switched power from it,
cant remember what the small one is for just yet, will have a look tomorrow,
Postby matt dunn » Tue Sep 28, 2010 11:16 pm
frost wrote:cant remember what the small one is for just yet, will have a look tomorrow,
i think it also went into the same emissions ECU.
Postby Rick » Wed Sep 29, 2010 4:34 pm
Just double check the wires to whats on your cluster, you can check by tracing it on the circuit board on the back of the cluster.
Postby Nizbit » Wed Sep 29, 2010 9:27 pm
ok sweet, hopefully i can work out the main ones i need (i.e. oil pressure, water temp) from the green plug,
Rick wrote:Image
is this looking at it from the back? i.e. no.1 will be on the white plug under the rev counter? it doesn't seam to match up
also where can i hook into for the rpm? cause i can't see it on that diagram
Nizbit
Postby dusk93 » Wed Sep 29, 2010 10:38 pm
By looking at the diagram I vote pin #15 as RPM come from Tachometer.
Current: 1983 AA60 Coupe, 1987 E30 318i coupe, 1985 SA70 Parts Heap, 1990 R32 GTST Coupe
Ex: 1982 AA60 Coupe, 1987 AE92 FXGT (RIP), 1989 Mazda Astina BG hatch, 1994 R33 Skyline GT ( RB20E powered :( )
dusk93
Postby Bling » Wed Sep 29, 2010 10:39 pm
15, tacho
Edit beaten :lol:
Postby Rick » Wed Sep 29, 2010 10:51 pm
here is another pic for a analog to digital conversion again double check against your cluster.
