Malcolm wrote:zener diode doesn't raise it, it eliminates it.
Akane wrote:Since ST185 does not have an awesome factory boost gauge like you get on the MR2, might as well rip the hose out and plug it up.
Malcolm wrote:Akane wrote:Since ST185 does not have an awesome factory boost gauge like you get on the MR2, might as well rip the hose out and plug it up.
yes it does
want to make any more statements for me to correct?
CelicaGT8 wrote:Im not runing the map sensor... so no line to unplug, its not there, still has boost cut tho
Akane wrote:WTF
Last time I took a ride in tranquil's car 4 years ago, I swear it didn't have the awesome boost gauge.
Maybe his car was a conversion from a 182........ lame.
Malcolm wrote:If it was converted from a 182 it would've been FWD and shitty, more likely that the gauges had been swapped or something. Or you're just blind.
