dynamic timing blacktop 4age carib
Postby hsmidy » Tue Oct 19, 2010 3:41 pm
hey guys
im just trying to check the dynamic timing on my 2000 carib its got a 4age blacktop i know how to check and adjust the timing however my trubble is i cant seem to get the timing light into a position to be able to get it to hit the crank pulley.
anyone had the same issue or know of and easy way to get aroudn this issue
thanks
hsmidy
Postby hsmidy » Wed Oct 20, 2010 11:38 am
bump, anyone?
hsmidy
Postby sergei » Wed Oct 20, 2010 12:13 pm
What is in the way?
You will need to bridge E1 with T(E)1 to get consistent result.
Postby hsmidy » Wed Oct 20, 2010 1:39 pm
p/s pump and hoses, engine mount, most of the engine bay..... might just have to remove the r/h inner guard.
those two terminals where abouts are they located?
hsmidy
Postby touge_ae101 » Wed Oct 20, 2010 1:45 pm
not sure if this is right but when i took my car to the mechanic to get timing done, he just used the timing light on the PS pump belt and #1 cylinder whilst bridging E1 and TE1.
touge_ae101
Postby sergei » Wed Oct 20, 2010 1:53 pm
Diagnostics tab is where to find the terminals to bridge.
Postby blindnz » Wed Oct 20, 2010 2:03 pm
you should be able to see the marks a little of center. down next to the mount. From memory the timing is to be done at 800rpm.
blindnz
Postby hsmidy » Wed Oct 20, 2010 3:06 pm
awsome thanks sergie
hsmidy
