pcv valve/ breather. 4age
Postby tim_blair » Tue Oct 19, 2010 10:52 pm
what is the best setup for running an oil breather can?
i currently have the pcv valve connected and running to the vacume manifold as is standed and have the other end of the cam cover which usualy goes to the intake now running to an oil catch can
what is the best way to do this?
should i remove the pcv valve and run both ends of the cam cover to the oil catch/breather can?
girl: can I trust you?
me: you can trust anything :D
tim_blair
Postby tim_blair » Tue Oct 19, 2010 10:53 pm
black top by the way
tim_blair
Postby Flannelman » Wed Oct 20, 2010 7:43 pm
how you have it is good
Flannelman
formerly known as Affroman
Postby tim_blair » Thu Oct 21, 2010 4:09 pm
but wont it be sucking oil and air through the vac manifold?
wont it run better without
tim_blair
Postby touge_ae101 » Thu Oct 21, 2010 4:38 pm
you can run a catch can in either of two ways
- as a vented catch can with filter on top (nothing enters the throttles)
- as a sealed catch can (the oil gets trapped in the catch can before the rest of the air travels on through to the throttles)
which is best is really up to personal preference and the condition of the motor itself. with venting it you can sometimes get a small wiff of oily smell when idling or if you have been thrashing it. not really that noticable though.
i run mine vented with a filter cuase i really don't want any of that shit getting into the throttles.
there are different opinions out there on this topic but at the end of the day it comes down to the condition of the engine and how much thrashing you do.
well and of course it does look nice too.
this is how i run mine and it seems to work very well. most people run it this way also.
block off the connection going into the manifold (or else you'll ahve idle issues) and run both of the camcase breather lines to the catch can. job done easy.
touge_ae101
Postby tim_blair » Thu Oct 21, 2010 7:51 pm
yea that sounds like me
nice looking engine bay by the way
tim_blair
