Boost_4_Life wrote:the honda would be sequential no? and link wasted spark (unless i buy a flash new link) ...?
whynot wrote:If you look closely under the throttle bodies you will see a small vac line which is joined into each throttle. I am pretty sure it then joins into the vaccum manifold on the right hand side of the motor next to where the ICV is plumbed into. thats where i got my vac signal from.
