ST215 Caldina sunroof wont open.
Postby cat007 » Fri Dec 31, 2010 10:45 am
Hey
My partners sunroof has stopped working. The car was sitting for about 3 months and it hasn't worked since. Pressing one of the buttons has the motor making a noise as if it's going to work, for a 10th of a second, but the glass doesn't move.
I can wiggle and push the glass up and down ever so slightly, so it's not stuck. I've tried banging the glass while pressing all the buttons hoping to free it but to no avail.
Any suggestions on what part of these could lock up over time?
Should I just spray wildly with some WD40 and let it soak?
Hunt
Postby celica_xr9145 » Fri Dec 31, 2010 11:40 am
has it came off the runners?
www.Garage-X.org - Car Awesomeness
Facebook.com/garagexnz - Now on FB!!
95' Zenki Silvia S14, 99' BMW 328i E46
celica_xr9145
Postby h8wrxs » Fri Dec 31, 2010 11:54 am
[/img]
The four seasons in Australia consist of "$&#$% it's hot", "Can you believe how $&#$% hot it is?", "I won't be in today because it is too $&#$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Postby cat007 » Fri Dec 31, 2010 12:57 pm
celica_xr9145 wrote:has it came off the runners?
Not that I can see. The motor doesn't work for very long. It's like if you wind a window almost all the way up, then you press the button and it goes up a little more....
Hard to describe sorry
Postby andyztouring » Sun Jan 02, 2011 9:52 pm
Have you taken the cover off the motor and turned with it an allen key(you will see an allen key slot in the centre shaft of the motor).The cover may be part of plastic surround with the rear view mirror or a round plastic disc in the headliner.
andyztouring
Postby cat007 » Tue Jan 04, 2011 4:22 pm
Ok so there's no allen key anywhere.
Here's what under the front interior light:
And here's a video of what the motor tries to do when pressing the forward then back "slide" buttons for the sunroof:
http://www.youtube.com/watch?v=W26x3EvtaHs
Postby Caldina3SGTE » Tue Jan 04, 2011 6:06 pm
mine done that once but mine open like a tiny bit then stopped couldn't under stand why so i dropped the trim off and found one of the screws on the side had some how make its way out of its whole and was jamming it
Caldina3SGTE
Postby cat007 » Tue Jan 04, 2011 7:01 pm
How does the trip drop off? Looks a bit like its glued in place?
