Sticky residue on wires - how to clean off?
Postby cat007 » Tue Jan 11, 2011 9:43 am
I've taken my wiring loom apart and tidied it up a little - the only problem now (although it's not a major) is the previous electrical tape I used to wrap it all up, has left a horrible sticky residue behind.
What can I use to get rid of this? Will degreaser help? And what should I use instead of electrical tape to wrap up the wiring loom? Or is electrical tape the best solution?
Hunt
Re: Sticky residue on wires - how to clean off?
Postby sergei » Tue Jan 11, 2011 9:57 am
cat007 wrote:I've taken my wiring loom apart and tidied it up a little - the only problem now (although it's not a major) is the previous electrical tape I used to wrap it all up, has left a horrible sticky residue behind.
Hunt
Good quality electrical tape is the way. Occasionally you can use heat shrink on exposed areas, or where you want a tight bind.
Postby Alex B » Tue Jan 11, 2011 10:46 am
de-solvit, get it from mitre 10 etc.
Postby DeeCee » Tue Jan 11, 2011 10:53 am
wax and grease remover
GT Four Adovansu
DeeCee
Postby Heylin » Tue Jan 11, 2011 12:20 pm
Desolve-It, Wax\Grease Remover, or Simple Green
Heylin
Heylin
Postby cat007 » Tue Jan 11, 2011 8:45 pm
Heylin wrote:Desolve-It, Wax\Grease Remover, or Simple Green
I bought a small bottle of de-solv-it. Small because HOLY CRAP have you seen how expensive it is haha
Postby Bling » Tue Jan 11, 2011 8:58 pm
What did you give up, an arm or a leg? Yeah bloody expensive :?
Postby jondee86 » Tue Jan 11, 2011 10:10 pm
cat007 wrote:And what should I use instead of electrical tape to wrap up the
You can buy a specific "loom tape" that works just like ordinary
electrical tape, but comes off easier, and without leaving the sticky
residue on your wires. Ask for it at an auto electrical supply shop.
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby levinguy » Tue Jan 11, 2011 10:24 pm
prepsol is what you want. got some from some car paint company a year or so ago, was about 15-20 bucks for a 1.5 l tin.
levinguy
Postby cat007 » Tue Jan 11, 2011 10:28 pm
levinguy wrote:prepsol is what you want. got some from some car paint company a year or so ago, was about 15-20 bucks for a 1.5 l tin.
Dam forgot all about that stuff!
I'll see how I go with De-Solv-it and if it's no good (altho it better bloody be for the price!) I'll get some prepsol
