what are the ratios for a st215 manual box
Postby headshotnz » Wed Mar 16, 2011 2:27 am
As title, mate brought a gen 4 3sgte plus a manual that came with it, he is putting it in his st185.
First of all, what is the ratios for said box.
and the code for it, I assume E series gearbox?
and is the final drive ratio compatible with the rear diff.
Had a look around google and couldn't find sweet F all :s Not up to my normal googling..
Cheers for any help :)
James
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Postby strx7 » Wed Mar 16, 2011 6:49 am
i'd be sticking with a st185 box as they dont break, st215 boxes break often.
ratios are the very close to, if not the same as st185. centre diff/rear diff ratio is the same
Postby strx7 » Thu Mar 17, 2011 4:51 pm
the ST215 GT-T box is an E150
Postby GTTpower » Thu Mar 17, 2011 4:56 pm
Cant say ive seen a GTT E150F box break, unless you count front diffs :wink:
1999 SXE10 Altezza RS200Z
2004 Honda SCV100
Steam/Origin ID: nzEP85
GTTpower
